On my local network I have one F4-220 and one F5-221 along with an Unraid server. The F4-220 is running TOS 5.1.123 and the F5-221 is running TOS 4.2.40.
I have purchased a CyberPower UPS model CP1000AVRLCDa and connected via USB to the Unraid server. I have also installed the NUT plug-in and everything appears to be working properly.
I then tried to get the F5-221 to see the UPS and was successful (I think!). Here's a screenshot:
However, when I try to set up the F4-220 the same way it fails to connect to the UPS. Here's a screenshot:
Anyone have any idea why connecting to the UPS in TOS4 appears to work correctly but not in TOS5 ??
Thanks for any help . . .
TOS4 & TOS5 and UPS
- Gandalf1369
TOS4 & TOS5 and UPS
Re: TOS4 & TOS5 and UPS
Did you click "Apply"? Is there any error prompt?
- Gandalf1369
Yes - I did click "Apply".
The error message flashes by extremely quick. All it says is "Cannot connect to server. Check IP address and make sure it is on".
- crisisacting
- Silver Member
{L_BUTTON_AT}Gandalf1369
If you can ssh onto that unit, Code: Select all
dmesgRe: TOS4 & TOS5 and UPS
This may be a UI problem from the old version. Please clear the browser cache, reopen the control panel module, reselect "tnas UPS server", fill in the IP, and then confirm again.
- Gandalf1369
No luck. Cleared the browser cache and tried again. Still can't connect in TOS 5. Also tried a totally different browser and still can't connect.
