Add new drive stuck in JBOD
Chowda
Post by Chowda »
F4-210
Added 14 TB to 3x 4 TB, I turned if off and on to realize it is in JBOD.
Now I've set it up again and its split the new drive into a new volume.
How can I merge to only have 1 volume and back into RAID?
indbreakertoas
Bahamas
Re: Add new drive stuck in JBOD
Post by indbreakertoas »
Hello, have you found a solution yet? I just accidentally separated 2 drives and don't know how to merge them. Hope someone will help!
David Evanscluster rush,
This is the method you can refer to:
viewtopic.php?t=1542
It is difficult for us to determine the specific situation regarding your description of "two hard drives being separated". We suggest that you collect a report from TOS>Technical Support>Problem Feedback and send it to the technical support email for inspection.
Return to “Network”
