Failed Hard Drive
aj2703
Failed Hard Drive
Post by aj2703 »
I had a raid 1 setup and one of the drives has failed.
I keep getting a massive beeping and it says drive not found in Tnas.
So I have ordered another drive.
How do I put the data onto the new drive exactly how it was on the other..?
Re: Failed Hard Drive
hi, you just need to pull the defective drive out from your tnas, and insert the new one into the slot. Go to TOS > control panel > storage manager > storage pool, click "Edit", and select "repair RAID".
aj2703
Post by aj2703 »
Thank you :-)
