What would cause just one of two F5-221 just disapere from the network?
Tricky
Post by Tricky »
Both connected to the same switch, yet one suddenly disappears from the network? This has happened several times before and in the past I have had to totally reinitialise the unit IE format each disk and start again, this time I was lucky and just turned off and on and it's back.
titanrx8
Re: What would cause just one of two F5-221 just disapere from the network?
Post by titanrx8 »
I have the same with two f2-221s. Both connected side by side to the same switch. Been happening for years. Even if I rearrange the network cables, it's ialways the same server. It hasn't mattered any version of the TOS. I assume it's the I/O board. When it happens the machine can't be pinged and it's invisible to the router and firewall. Usually a manual reboot fixes it for another week or two.
Tricky
Post by Tricky »
Exactly that! Dam annoying mine runs all the same version and apps and is configured the same, it will run fine for a week or so that nothing.
titanrx8
Post by titanrx8 »
BTW, when I contacted tnas support regarding buying a new I/o board they wouldn't sell me one. Only interested in selling me an entire new machine.
Incidentally, the same machine also has an intermittent on-off button. Once in a while the machine will power on by itself, not in accordance with the power schedule I have set. It will also ignore button presses. When that happens, I disassemble the machine and flood the button with contact cleaner which fixes that problem for a few months.
The funny thing is that the misbehaving machine is newer than the one that never hiccups.
When randomly dropped, you can try to check whether the hard drive is healthy:
viewtopic.php?f=81&t=915
How to know whether the hard disk health: viewtopic.php?f=82&t=1125
If you did not setup a power schedule, and your TNAS just constantely reboot by itself in several minutes, please contact with tech team for a replacement. The issue is likely to be due to device hardware failure.
Contact tech team: viewtopic.php?f=75&t=608
Return to “Network”
