I have a F4-423 and yesterday it lost its connection to the internet. The WAN shows disconnected. I also have a F4-210 which is working fine.
I am not shure why this happend as it has been working with no issues for several weeks (ever since I first connected it to my network)
Only one LAN port appears to work to connect to my network. The 423 has 2x 2.5g LAN ports. When I connect it to the other LAN port, the connection times out.
I am able to connect to the NAS fine using the one LAN port and access the desktop etc.
I have sent a request into support about this, but while I am waiting I thought I would ask in this group for any ideas.
Disconected WAN (Internet)
F4-423 TOS 6.0.673 - Plex Server and media
F4-223 TOS 6.0.673 - Backup for Plex server and media
- eddiedulac
Re: Disconected WAN (Internet)
I used to have the same problem. Then, it was solved after I replaced the Ethernet cable I am using to connect the F4-423 NAS with a known working cable. You can try applying this method
- Eddie- suika game
Thanks for the help.eddiedulac wrote: ↑01 Mar 2024, 07:11 I used to have the same problem. Then, it was solved after I replaced the Ethernet cable I am using to connect the F4-423 NAS with a known working cable. You can try applying this method
I finally figured out what my issue was. It turned out to be the way I hd entered in the Google DNS for my TNAS ports. Changing it back to automatic got it working again.
