Hello - I have a new F4-423 and I want to configure LAG on it. When I navigate to Control Panel-->Network, I cannot find where that configuration is. There does not seem to be a button, screen or option for configuring a NIC bond/LAG/NIC Teaming. I see older forum posts about this, however, I do not have these options in my setup. What am I missing?
Thanks!
Dain
How to configure LAG in TOS 5.1?
- godmakesnew
F4-423, 4G RAM, 2x12TB Drives
Re: How to configure LAG in TOS 5.1?
Try COntrol Panel > Network > Interface
Just above the Connections block should be a small '+' icon. This will only be valid if (at least) 2 interfaces are connected/active.
Frustrated Beta Tester!!!
- godmakesnew
Ah thank you! I didn't have the second interface connected. Now I see it and was able to successfully bond the NICs. I'm using an Ubiquiti UNIFI 8 ports switch and 802.3ad LAG.
https://support.hostifi.com/en/articles ... itches-lag
