Is it just me, but none of the help documents I have tried to access will load for me.
For example: https://help.terra-master.com/TOS/view/ ... dia_server
It trys to load, but all I get is a spinning circle in the centre of the screen. If I wait an hour or two, sometimes some of the words partially appear, but no images.
TOS Help articles do not load
F4-423 TOS 6.0.673 - Plex Server and media
F4-223 TOS 6.0.673 - Backup for Plex server and media
Re: TOS Help articles do not load
At the moment it does look like the TM main sites are having an issue. Could be they are doing updates (Sunday evening/night as I write).
Thank you for your report! it seems there are some issues there, we will verify and fix them soon.
Thank you. Everything is loading nice and fast now.
Hmmm
'www.terra-master.com'Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /home/@terramaster/wwwroot/www.terra-master.com/lib/Zend/Db/Adapte ... ct.php:128 Stack trace: #0 /home/@terramaster/wwwroot/www.terra-master.com/lib/Zend/Db/Adapte ... t.php(128): PDO->__construct('mysql:host=127....', 'terramaster', 'terramaster0502', Array) #1 /home/@terramaster/wwwroot/www.terra-master.com/lib/Zend/Db/Adapte ... l.php(111): Zend_Db_Adapter_Pdo_Abstract->_connect() #2 /home/@terramaster/wwwroot/www.terra-master.com/lib/Varien/Db/Adap ... l.php(396): Zend_Db_Adapter_Pdo_Mysql->_connect() #3 /home/@terramaster/wwwroot/www.terra-master.com/lib/Zend/Db/Adapte ... t.php(460): Varien_Db_Adapter_Pdo_Mysql->_connect() #4 /home/@terramaster/wwwroot/www.terra-master.com/lib/Zend/Db/Adapte ... t.php(238): Zend_Db_Adapter_Abstract->query('SET NAMES utf8', Array) #5 /home/@terramaster/wwwroot/www.terra-master.com/lib/Varien/Db/Adap ... l.php(504): Zend_Db_Adapter_Pdo_Abstract->query('SET NA in /home/@terramaster/wwwroot/www.terra-master.com/lib/Zend/Db/Adapte ... stract.php on line 144
