Issue with Nextcloud from Linuxserver.io
Discussion about Docker
super-6-1
Post by super-6-1 »
So i having a issue with this container. I keep getting Exception: Not installed in /app/www/public/lib/base.php:283 and this happens over and over. I have posted the log and the yml file i use to make it. Is there a issue i don't know about?
[migrations] started
[migrations] 01-nginx-site-confs-default: skipped
[migrations] 02-default-location: skipped
[migrations] done
   Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User UID:    3
User GID:    4
using keys found in /config/keys
Initializing nextcloud 28.0.1.1 (this can take a while) ...
Setting permissions
New nextcloud instance
Please run the web-based installer on first connect!
Initializing finished
After completing the web-based installer, restart the Nextcloud container to apply default memory caching and transactional file locking configurations.
Alternatively, you can apply your own configurations by editing /config/www/nextcloud/config/config.php following the documentation:
https://docs.nextcloud.com/server/latest/admin_manual/configuration_server/caching_configuration.html
https://docs.nextcloud.com/server/latest/admin_manual/configuration_files/files_locking_transactional.html
[custom-init] No custom files found, skipping...
[ls.io-init] done.
Stack trace:
#0 /app/www/public/lib/base.php(709): OC::checkInstalled()
#1 /app/www/public/lib/base.php(1200): OC::init()
#2 /app/www/public/cron.php(43): require_once('...')
#3 {main}
Stack trace:
#3 {main}
YML file
services:
  nextcloud:
    image: lscr.io/linuxserver/nextcloud:latest
    container_name: nextcloud
    environment:
      - PUID=3
      - PGID=4
      - TZ=America/New_York
    volumes:
      - ./config:/config
      - ./data:/data
    ports:
      - 8080:8080
    restart: unless-stopped
Anyone know what can cause this?
Mordac85
Re: Issue with Nextcloud from Linuxserver.io
Post by Mordac85 »
Looks like you need to post valid paths for ./config and ./data
F5-221
TOS 5.1.67
4 x 4TB RAID5 EXT4
1 x 8TB EXT4
Return to “Docker”
