Why can't Plex Scan Files after Adding Media Library Files?
TMnight
Post by TMnight »
Applicable Version: TOS 5
Applicable Models: All TNAS Models (excluding F2-210 and F4-210 models)
Symptoms: Plex cannot scan files after adding media library files.
Cause of the Issue: The shared folder added to Plex does not have the necessary permissions for the media user group.
Solution:
1.Please set media user group permissions for the shared folder added to Plex. Go to TOS Control Panel > Shared Folders, select the relevant shared folder, click the "Edit" button, and configure read and write permissions for the media user group.
2.Please close the Plex application first, and then restart the Plex application.
trigg67
Re: Why can't Plex Scan Files after Adding Media Library Files?
Post by trigg67 »
TMnight wrote: 30 Jan 2024, 17:52 Applicable Version: TOS 5
Solution:
thank you for this
Return to “Applications”
