Troubleshooting
Applicable model: All models
If your hard drive is not able to be detected by your TNAS device, or RAID formatting fails during installation(RAID formatting stuck at 10~80%), please try followings:
1. Make sure your hard drive is well attached to the tray, and well seated on its position; Release your drive from the tray and fix it again, and insert it back to the cabin. Please refer to following video guide to install your drive correctly. https://youtu.be/Z6c6S7AA1TE
2. Make sure your hard drive is healthy and in compatibility list;
3. Remove your drive from your TNAS, and test and repair it with third party professional disk tools; viewtopic.php?f=75&t=1125
4. Do a low-level formatting, and try again;
5. If you still encounter a failure, replace it with a new drive and try again.
TerraMaster NAS fails to detect my hard drive?
