Hi
I want to run a Python 3.8 script on my F4-210. I installed Python from the "Applications Store" with Cron_okm to make a reboot cron action to start the Python script every reboots
To debug it, it run with this command : */2 * * * * MyUser /usr/local/bin/python3.8 /mnt/md0/MyCoolSharing/WebServer/main.py >> /mnt/md0/MyCoolSharing/WebServer/log_api.log 2>&1
Inside the log file I got :
/usr/local/bin/python3.8: error while loading shared libraries: libpython3.8.so.1.0: cannot open shared object file: No such file or directory
It's a Flask server, So Python 3.8 is required.
I found the file at "/mnt/md0/application/lib/" with a SSH connexion.
How I can fix this issue ? Will a Docker container fix it (And how to do it to run my script and save files on my disks) ?
Note :
In my SSH connexion I can do "python /mnt/md0/MyCoolSharing/WebServer/main.py" and I run. Why the CRON don't found the required Python library ?
Any help appreciated !
Python 3.8 failed to load shared libraries "libpython3.8.so.1.0" (F4-210)
- MiniChaKal
- lesliewang
Re: Python 3.8 failed to load shared libraries "libpython3.8.so.1.0" (F4-210)
First, I think you should update the LD_LIBRARY_PATH: The LD_LIBRARY_PATH environment variable is used by the system to locate shared libraries. You can try updating it to include the directory where the libpython3.8.so.1.0 library is located. Run the following command in your SSH session:
Secondly, you can try modifying the Cron Job. Update your cron job command to include the updated LD_LIBRARY_PATH. Modify your cron job entry to something like this:
This command sets the LD_LIBRARY_PATH environment variable before executing the Python script.
bash
export LD_LIBRARY_PATH=/mnt/md0/application/lib:$LD_LIBRARY_PATH
This command adds the "/mnt/md0/application/lib" directory to the LD_LIBRARY_PATH.Code: Select all
bash
*/2 * * * * MyUser env LD_LIBRARY_PATH=/mnt/md0/application/lib /usr/local/bin/python3.8 /mnt/md0/MyCoolSharing/WebServer/main.py >> /mnt/md0/MyCoolSharing/WebServer/log_api.log 2>&1- lesliewang
Hope that my answer is useful for you. fnaf 2
