all files are 0 byte
DERIKKU
Post by DERIKKU »
After a night i wonder that i have more space on my nas. then i look ,, all files are 0 byte and i can't open. i can't send the debug file to terramaster sippurt (it is to big). What can i do noe?
F5-221
TNAS 10TB
RAM 10GB
spa
Australia
Re: all files are 0 byte
Post by spa »
I'm not sure whether you fixed your problem or not, but I found a solution for my specific situation that, by the saying of it, sounds very similar to yours.
If you can wire in an external USB drive or if you have some free space somewhere else, maybe it could work for you as well...
Good luck.
Terramaster 0 bytes files
oilumiun12
Post by oilumiun12 »
spa wrote: 07 Apr 2024, 08:02 Hi,
Good luck.
Connecting an external USB drive feels complicated, but it's a good place to store information for me
