How can I check the runtime/lifespan of a disk?
I bought two IronWolf 4TB disks, and I would like to verify if they are new. I am not sure because they emit a sound every 10-15 seconds, as if the head were moving.
Disk runtime/lifespan
Re: Disk runtime/lifespan
You can go to TOS > Control Panel > Hard Drive > S.M.A.R.T, check "Power-Ond_Hours" to confirm the usage time of the hard drive.
You can also use the disk tools to check when you connect the disk to PC:
viewtopic.php?f=82&t=1125
Thank you for your reply.
The problem is that there is no data in the S.M.A.R.T section (screenshots are attached).
My TNAS model is F2-223.
TOS version is 5.1.103-00409 (upgraded online).
I cannot connect the disk to my PC because I do not have the possibility to do so.
Any other ideas?
Any other ideas?
Please click on the last button on page S.M.A.R.T to open and view SMART information of the disks.
I have got it. Thank you.
We can close topic.
We can close topic.
Still curious as to results.
