Nested Folders not sent to S3
camoffat
Post by camoffat »
Hello! I need some help. I set up Cloud Sync to send from my Local to S3. I set up a test folder, with files and nested folders, to send test pictures to validate the connection
Test_Folder\
<files>
Folder_1\
<files>
Folder_2\
<files>
Full path: Test_folder\Folder_1\Folder_2. When I sync Test_folder\<files> & Folder_1\<files> get copied or synced, but Folder_2 and it's contents do not get synced to S3. Is there a limit on the depth (1?!) on nested folders for Cloud Sync?
The TM log only indicates successfully transmission. The version of Cloud Sync is 2.4.26. Happy to send screen shots, etc. Thank you in advance!
TMtina
Re: Nested Folders not sent to S3
Post by TMtina »
CloudSync has no limit on the depth of nested folders. Is the file transfer in Folder_2 successful as shown in the log? Can you export the log and provide us with a screenshot?
Return to “CloudSync”
