How to install Home Assistant on Docker
Discussion about Docker
giluka
Post by giluka »
is there someone who install with success Home Assistant using Docker ?
Could you share documentation to do that ?
I'm using model F2-212 with TOS Version 5.1
Thanks !!
using F2-212
Mordac85
Re: How to install Home Assistant on Docker
Post by Mordac85 »
The docs are kinda buried but you can find them at the Home Assistant site if you use the search function.
F5-221
TOS 5.1.67
4 x 4TB RAID5 EXT4
1 x 8TB EXT4
Mordac85
Post by Mordac85 »
fwiw, those instructions are for installing the app on your NAS, not running it as a Docker container.
F5-221
TOS 5.1.67
4 x 4TB RAID5 EXT4
1 x 8TB EXT4
The step by step instructions from the link above are to install homeassistant as a docker container. tmnascommunity.eu provides 3rd party apps which runs natively on the NAS and also step by step guides to deploy docker containers.
Mordac85
Post by Mordac85 »
My apologies. I should have read through that before putting my foot in my mouth :oops:
F5-221
TOS 5.1.67
4 x 4TB RAID5 EXT4
1 x 8TB EXT4
Return to “Docker”
