[ NodeRED ] Low-code programming for event-driven applications
About: https://nodered.org/
Category:
Applicable models: x.64 series, ARMv8.2 series
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.37 or later versions
Applicable TOS6: 6.0.124 or later versions
App download: https://tmnascommunity.eu/download/NodeRED
Required packages:
NodeJS
TOS4: http(s)://yournasip:port/modules/pgAdminOKM/www
TOS5 & TOS6: click on Support & Help from app description inside the App Center
Node-RED is a programming tool for wiring together hardware devices, APIs and online services in new and interesting ways.
It provides a browser-based editor that makes it easy to wire together flows using the wide range of nodes in the palette that can be deployed to its runtime in a single-click.
