Accessing Static ip LAN docker server using second LAN Dynamic Public IP
pindiplus
Post by pindiplus »
Hi
I have F2-223 Device. it has 2 LAN ports which can have 2 separate IPs
LAN1 is connected to A local network with IP 130.2.2.99 and my Docker container is running at http://130.2.2.99:776
LAN1 has no internet but i want to access my docker container.
Can i connect a internet router to the second LAN port and access the http://130.2.2.99:776 ?
TMLeeh
Re: Accessing Static ip LAN docker server using second LAN Dynamic Public IP
Post by TMLeeh »
Yes, you can connect an internet router to the second LAN port.
pindiplus
Post by pindiplus »
Hi
if i connect internet router to second LAN and then
if i connect laptop to the same internet router , will i be able to access http://130.2.2.99:776 ?? will it find this ip?
iciclebalance
Post by iciclebalance »
pindiplus wrote: ↑15 Jan 2024, 21:46 Hi
Can be connected to that second LAN port. Have you tried connecting yet? Can you explain more clearly what problem you encountered?
AngelicChanel
Post by AngelicChanel »
Connect one of the LAN ports on your internet router to the second LAN port (LAN2) on your F2-223 device using an Ethernet cable.
Return to “Network”
