[ StirlingPDF ] Your locally hosted one-stop-shop for all your PDF needs
About: https://stirlingtools.com/
Category:
Applicable models: x.64 series, ARMv8.2 series
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.37 or later versions
Applicable TOS6: 6.0.124 or later versions
App download: https://tmnascommunity.eu/download/StirlingPDF
Required packages:
OpenJDK18
TOS4: http(s)://yournasip:port/modules/pgAdminOKM/www
TOS5 & TOS6: click on Support & Help from app description inside the App Center
This is a powerful locally hosted web based PDF manipulation tool that allows you to perform various operations on PDF files, such as splitting merging, converting, reorganizing, adding images, rotating, compressing, and more. This locally hosted web application started as a 100% ChatGPT-made application and has evolved to include a wide range of features to handle all your PDF needs.
Stirling PDF makes no outbound calls for any record keeping or tracking.
All files and PDFs exist either exclusively on the client side, reside in server memory only during task execution, or temporarily reside in a file solely for the execution of the task. Any file downloaded by the user will have been deleted from the server by that point.
epsilonion
Re: [ StirlingPDF ] Your locally hosted one-stop-shop for all your PDF needs
Post by epsilonion »
downloaded from community site installed and when enabling it fails.
Show screenshot from app web ui
anxo
Spain
Post by anxo »
HI!
This is the message showed by app as soon as you try to execute it even with admin accout
(Access denied !) - you need to login on TOS with an admin role account
any idea of what's going on here?
Enviroment
TOS 6.0.694
StirlingPDF TOS5 0.19.0.0 x86_64.tpk
The app is not ready for TOS6 > 6.0.420
