About: https://github.com/schlagmichdoch/PairDrop
Category:
Applicable models: x.64 series, ARMv8.2 series
Applicable TOS6: 6.0.124 or later versions
Applicable TOS7: 7.0.0124 or later versions
App download: https://tmnascommunity.eu/download/PairDrop
Required packages:
NodeJS22
TOS7 & TOS6: click on Support & Help from app description inside the App Center
PairDrop is a sublime alternative to AirDrop that works on all platforms.
File Sharing on your local network
Send images, documents or text via peer to peer connection to devices on the same local network.
Internet Transfers
Join temporary public rooms to transfer files easily over the internet!
Web-Application
As it is web based, it runs on all devices.
You want to quickly send a file from your phone to your laptop?
You want to share photos in original quality with friends that use a mixture of Android and iOS?
You want to share private files peer to peer between Linux systems?
AirDrop is unreliable again?
Send it with PairDrop!
