TOS: 5.1.67
Model: F4-420
Docker: Whatever the one is in App Center
So, I'm trying to install/run a container that I know wont be found on Docker Hub or wherever the GUI can pull from. But I wanted to know where to put the files on the NAS to hopefully grab it via docker-compose (which I haven't even tested is installed and may need help with that if it's not).
Inside the Docker GUI:
To test and start learning, I pulled down the latest Sonarr from LinuxServer. Before running it, I stepped through the guided setup and mapped three folders.
Inside the File Manager I clicked my username on the left and created the following folder structure:
/<username>/docker/sonarr/config {and I mapped that to} /configCode: Select all
/Volume1/environment/Media/Video/TV -> /tvCode: Select all
/Volume1/environment/Media/Video/downloads -> /downloadsI noticed in the real
/archigos/docker/sonarr/configCode: Select all
/tvI assume this is to do with permissions? There's a setting in Sonarr for "Recycle Bin" which dumps all deleted files there instead of perma-delete and I accidently just pasted in the 'real' location to that folder and got an error stating that "Folder '/<folder I entered>/' is not writable by user 'abc'" So I think Sonarr is actually using a username of abc so how do I fix that so it uses my username (which I hope will get around the permission issues)?
In SSH, running "find ./ -type d -name sonarr" shows that ./home/archigos/ is the same as ./Volume1/User/archigos/ not sure if that helps me in any way, unless maybe I can symlink the 'real' tv and download folders inside the /home/archigos/docker/sonarr/ folder and try to set the locations to that? But that probably wouldn't help if it is a permission issue right?
Any help/suggestions would be greatly appreciated.
