Encrypted Shared Folder automount after reboot / startup
rockblock
Post by rockblock »
I am following up on this topic - the original thread from 2020 was closed without a resolution and would like to know when will this be implemented, especially since over 3 years have passed with no update?
This refers to folders being unmounted after a reboot, power loss or schedules setup, which should not happen
It's quite annoying to have to re-mount all folders after a reboot, especially if you have hundreds of them. Other NAS (WD, QNAP, Synology, etc) have been implementing this feature for 15+ years now, so how hard can it be? Once a folder has been mounted, it should remain in a permanent state, and only change upon user intervention.
This is very counter productive if you have a regular shutdown/startup schedules setup
So can we pls have an update as to when this will be implemented - will this be done as a hot-fix to 5.1.... or TOS 6?
P.S. This is also counter productive if you have a reboot schedule setup
Thank you
Re: Encrypted Shared Folder automount after reboot / startup
Thank you for your suggestion, we will discuss it.
