[ Leantime ] Open Source Project Management Software
About: https://leantime.io/
Category:
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.37 or later versions
Applicable TOS6: 6.0.124 or later versions
App download: https://tmnascommunity.eu/download/Leantime
TOS4: http(s)://yournasip:port/modules/Leantime/www
TOS5 & TOS6: click on Support & Help from app description inside the App Center
Leantime is an open source project management system for non-project manager.
We combine strategy, planning and executing while making it easy for everyone on the team to use.
It's an alternative to ClickUp, Monday, or Asana. As simple as Trello but as feature-rich as Jira.
Task Management Project Planning Information/Knowledge Management Administration
Task management via
kanban boards, gantt, table, list and calendar views Project Dashboards, reports & status updates Wikis / Docs Easy installation
Unlimited subtasks and dependencies Goal & metrics tracking Idea Boards Multiple user roles and per project permissions
Milestone management Lean & Business Model Canvas Retrospectives Two factor authentication
Sprint Management SWOT Analysis canvas File Storage via S3 or local filesystem LDAP, OIDC integration
Timetracking & timesheets Risk Analysis Screen & webcam recording Integration with Mattermost, Slack, Discord and Zulip (more coming soon)
... and more Comments/discussions on everything Available in 19 languages
JosemariaBS
Re: [ Leantime ] Software de gestión de proyectos de código abierto
Post by JosemariaBS »
Lo consigo instalar como explicáis en el "manual", pero al cabo de un rato y ver su funcionamiento, se cierra la sesión del usuario y no vuelvo a entrar, ni con las claves que le puse, ni nada.
La aplicación es perfecta para mis necesidades y me gustaría resolver este problema.
