I have multiple TNAS units; I plan to sell an older one on Ebay.
How do I ensure that the device has none of my data left on it?
I will remove the hard drives from the caddies. But I am aware there is some TOS software installed internally in the unit, either on a USB stick or possibly on some other storage.
Is it guaranteed that none of my data (e.g. TOS setup with passwords, IP addresses) is present if I just remove the drives I added?
Selling one of my TNAS - remove all data
- crisisacting
- Silver Member
Re: Selling one of my TNAS - remove all data
The internal USB is purely for initialization; there's no user data stored on it as it looks for a certain path on mounted HDD(s) to boot from that/those if TOS is installed, otherwise it'll load from the USB to go through the initial boot wizard.
Removing your caddied drives has sufficiently taken your data away.
- Archibalded
If you're uncertain whether the factory reset removed all sensitive data, you can contact TerraMaster support for guidance. They can confirm if a factory reset erases all user data from internal storage.By removing the drives and performing a factory reset (or reinstalling TOS), your TNAS unit should be clean and ready for sale.
When life gets you down remember -best sex dolls
It's only one down and the rest is UP!
