I have read in this forum that when we create a storage pool, TOS makes four partitions on the disk, boot partition, swap partition, system partition, and data partition.
I have also read that, If there are multiple disks in TNAS, each disk is treated as a system disk, and the Swap partition and system partition on each disk are assembled into a RAID 1 array, ensuring that system configurations and database change data are backed up on each system disk, providing flexibility for disk replacement.
I'm doing tests on my nas, since I'm new to this topic.
I had a Raid 1 on my NAS, with only a few gigabytes of information in my user folder, specifically photos for Terra Photos.
Since you cannot go from Raid 1 to Traid, I made a new storage block in Raid with another hard drive.
Once this is done, I turn off the nas and remove this new disk, turning on the nas with only Raid 1 with the photos in my user folder.
I delete the volume, and the storage block.
I turn off the NAS, and connect the Traid disk only.
I have lost the information in the user folder, and the Terra Photos application
Does anyone know why?
Disk Partitions TNAS - Help
TMzzl
Re: Disk Partitions TNAS - Help
{L_BUTTON_AT}Marin
Apps are downloaded to the default volume, and if you delete them accidentally, they will be lost along with data and configuration.
This bit. You don't appear to have made a backup or copy of the data before deletion.
{When you created the TRAID, only the system partitions are recreated as raid 1 mirror. The storage partitions (Volume1, etc) are untouched. All your data and apps are on Volume1, etc.}
