CloudSync randomize block
teicang
Post by teicang »
Hi , I activate the Sync with google drive, I want say the app didn't works well, the most of time also if is correct configured when I try so see the remote google drive folder to configure the task , it's remain freeze, at the end I just select the / to import all the structure.
However after a several attempt I been able to activate the connection a create the task.
Task started to running and folder started to import, BUT after several hour checking the status again I got Drive online BUT task not active, try to activate it again but it failed, checking in the error log the error is "Failed to get the fs type"
I'm quite sure to activate it again I need to remove task, remove connection and start all the process again.
In this way logically I cannot use it.
Any idea? or something wrong on my side?
thx
\Gianni
TNAS model F2-422
SO 5.1.95
cloudSync 3.0.16
Re: CloudSync randomize block
We will confirm the situation you mentioned
Also, is your TOS system partition 2GB or 8GB?
(You can determine the capacity of "\" by viewing it in Resource Monitoring - Overview.)
teicang
Post by teicang »
Hi all,
thx for the answer, i try to see what you mentioned,
is this what do you refer?
I haven't set it so I suppose is something of automatic.
Can I change it in some way?
many thx
ColaChen
Post by ColaChen »
{L_BUTTON_AT}teicang
Too small system partitions from TOS4 may cause some problems when using TOS5.1, and if you are not sure if it will also affect your use of cloudSync, please refer to this link to understand and find solutions:viewtopic.php?f=28&t=4912
Return to “CloudSync”
