Scheduled Tasks on TFM Backup
TFM Backup is the abbreviation of TerraMaster Folder Mirror backup. TFM Backup is a dedicated backup tool for TNAS shared folders developed by TerraMaster.
mightymouse
Post by mightymouse »
How do you amend a schedule on TFM Backup? The schedule I set is not showing in the TFM Backup task so I attempted to save it a few times. Now if I go to General Settings > Scheduled tasks I can see all the scheduled task created by TFM Backup and I cannot delete or amend them. So I ended up with several backup schedules some even clashing with each other.
TMtina
Re: Scheduled Tasks on TFM Backup
Post by TMtina »
Edit the task in the TFM Backup, modify the scheduled task time, and check whether the next execution time is modified accordingly. If it still cannot be displayed, please go to the application center to restart the application and try again.
mightymouse
Thank you for the reply. The tasks were not showing up on TFM Backup. For future reference to others... I ended up Uninstalling the app (including deleting app data) and re-installing it and that sorted it out.
Have you ever updated TOS during task execution?
I suggest you provide relevant screenshots.
Renata98
India
Post by Renata98 »
mightymouse wrote: 21 Dec 2023, 21:02 How do you amend a schedule on TFM Backup? The schedule I set is not showing in the TFM Backup task so I attempted to save it a few times. Now if I go to General Settings > Scheduled tasks I can see all the scheduled task created by TFM Backup and I cannot delete or amend them. So I ended up with several backup schedules some even clashing with each other.
"Had a problem with TFM Backup wherein many backup schedules were inadvertently established, resulting in conflicts between them. Potential conflicts arise since you are unable to remove or modify them under General Settings > Scheduled tasks."Fm whatsapp
TMlinda
Post by TMlinda »
Renata98 wrote: 23 Aug 2024, 23:20
Version 1.0.124 of the TFM_Backup app has fixed this issue. You can uninstall the app first, check "Delete configuration" to delete the related scheduled tasks, and then reinstall the app.
Return to “TFM Backup”
