F2-210 Can't enter web admin after update
CarlosMtnez
Post by CarlosMtnez »
Hello, I just auto-update my Terramaster F2-210 and when I login in the web panel (credentials are correct) it stuck in an infinite loading.
I posted this few months ago
viewtopic.php?f=21&t=5016
I cannot enter by SSH to try again, root Admin123 are invalid, and now said is blocked due to failed attemps
My files are available over the SMB Network, but cannot enter to web admin.
Please, need help.
Re: F2-210 Can't enter web admin after update
The specific cause of this problem cannot be determined, and I am glad to know from here that you have resolved the problem.
viewtopic.php?f=96&t=5203
Please note that if it reappears in the short term, it is recommended to check your hard drives.
Return to “System Update”
