I want to enabe the recycle bin for the home folders in the home locaiton (/home/user).
Issue is if I go to "Shared FOlder" iun the control panel I do not have those folders listed there and cannot add them in rder to enable the recycle nin.
Please advise as I need to have the option to restore files that are accidentally deleted in this location.
Model: F4-423
TOS Version: 5.1.103-00409
Enable Recycle Bin for home folders
Re: Enable Recycle Bin for home folders
The personal home directory does not have a recycle bin mechanism, we will discuss your needs.
Re: Habilitar la papelera de reciclaje para las carpetas de inicio
Me interesa la solución a esta cuestión gracias
Thanks, I will create a seperate share and use that instead.
Hi @Henri
can you explain to us the solution you have found?
Thankyou.
Thankyou.
