Can't access to GUI
meninjey
Can't access to GUI
Post by meninjey »
I have screwed up.
I accidentally enabled the firewall to only port 23 on all devices to test, so now I can't access the GUI (port 8181), either locally or remotely.
What I can do?
Re: Can't access to GUI
You can edit the firewall file/etc/firewall/iptables. conf
If you ultimately fail, you can only try reinstalling TOS to reset it:viewtopic.php?f=76&t=423
n3cr0x
Post by n3cr0x »
Can u explain me pls how I can edit and save configs? Vi cant save file. ESC menu dont work. I have installed Nano but it cant start. How can I set up Rules for firewall when i give ssh port 22 tcp open and then save this. Thats all, i cant access my NAS.
Return to “Network”
