plex service stops running
scoobyfizz
Post by scoobyfizz »
over night my plex service appears to stop. There are two resources left running but the service is unreachable. When I go to the app it says stopped so I have to start it again. Any ideas?
Best thing I ever did was ebay my Terramaster...
Re: plex service stops running
Please advise your TNAS Model number and current TOS version in return. Please check this post for some solution : viewtopic.php?f=75&t=364
scoobyfizz
F2-210 TOS 4.1.24, plex version 1.19.2.2737.
problem seems to be when it tries to scan a library. it seems to crash the application. so it is I suspect the fact that either plex is out of date (as the same library is in use on my QNAP server and it scans fine) or there is a memory issue with the size of the library and the terramaster version.
Memory overflow could be the reason.
scoobyfizz
is there anyway to completely start afresh with PLEX on the terramaster NAS. I have tried the reset and also uninstalling and re-installing but somehow it seems to be remembering my settings (to the point I cant even delete libraries now so I think the database is toast) on my other nas I can access the plex media server directory but I cannot find it on the terramaster.
TOS Version4.1.24 Plex version 1.19.2.2737
Please uninstall Plex, and delete the Plex files at File Manager - admin - user - Plex
scoobyfizz
OK.. your post is a lite confusing but have found that now.. would have saved a lot of heartache that one..
Return to “Plex Media Server”
