TOS 5.1.103 (X86) is Released for Update
IMPORTANT NOTICE
Attention: TOS 5.1 System Update
If your initial system was TOS 4.x and your system partition is 2GB, please refrain from updating to the new TOS 5.1 version. The updated version demands more storage space, and this requirement may not be met by your current system.
How to Check Your System Partition Size:
Navigate to "TOS > Control panel > System Info > Overview" and inspect the available space under the "/" section.
In the event that your TNAS does not meet the storage conditions but you wish to proceed with TOS 5.1.103, please follow the guidelines provided here: viewtopic.php?f=28&t=4912
Release Notes
Applicable Models:
  • F2-220、F2-221、F2-223、F2-420、F2-422、F2-423、F2-424
  • F4-220、F4-221、F4-223、F4-420、F4-421、F4-422、F4-423、F4-424、F4-424 Pro、U4-111、U4-423
  • F5-220、F5-221、F5-420、F5-421、F5-422
  • T6-423
  • F8-421、F8-422、U8-111、U8-420、U8-423、U8-450、U8-322-9100、U8-522-9400、U8-722-2224
  • T9-423、T9-450
  • T12-423、T12-450、U12-420、U12-423、U12-322-9100、U12-722-2224
  • U16-420、U16-322-9100、U16-722-2224、U16-722-2288
  • U24-612、U24-722-2224
What's New:
  1. Adapted to Terra Photos 1.2.90 and modified the method for retrieving video thumbnails.
Bugs Fixed:
  1. Fixed the issue where the date and day of the week of the time page in Control Panel were not promptly updated.
  2. Fixed the issue of occasional misconfiguration of permissions when editing shared folders.
Important Notes:
  • Users of TOS 5.1.37 should be aware that encrypted folders created in this version may face decryption issues in subsequent updates. It is recommended to back up data in the encrypted shared folder and delete it before proceeding with the update. This applies only to encrypted shared folders created in TOS 5.1.37.
  • The kernel of TOS 5.1 has been updated to 5.15. As a result, Intel Celeron J1800/J1900 GPU drivers are no longer supported in these models. If you rely on GPU hardware video acceleration and own any of the affected models, avoid updating to TOS 5.1. These models include F2-220, F2-420, F4-220, F4-420, and F5-420.
  • While the system update typically doesn't affect your hard drive data, it is strongly recommended to back up your data to ensure its safety before proceeding with the update.
How to Update Your TOS:
Manual Update:
  1. Download the update package here (md5: 5af01b08a0906cb354e4f40259563970).
  2. Go to TOS > Control Panel > General Settings > System.
  3. In the "Manual Update" section, upload the update package.
  4. Click "Apply."
  5. After the system update is complete, refresh your web browser.
  6. Note that your TNAS's IP address may change after the update; if you can't connect with the previous IP, search for the new IP using the TNAC PC client.
TNAS PC:
After updating to TOS 5.1, ensure that your current TNAS PC is updated to version 5.0.33 or a later version. This step is essential for searching your TNAS device.
Download TNAS PC 5.0.35 for Windows OS
Download TNAS PC 5.0.41 for macOS
It is recommended to uninstall the previous version before installing this version of TNAS PC.
Issue Report:
If you encounter any issues during use, please report them on the TerraMaster official forum, or email your issue description and screenshots to pm(at)terra-master.com.
desallesp
Re: TOS 5.1.103 (X86) is Released for Update
Post by desallesp »
Morning, I'm trying to update but it says my system partition is less than 8 gb and it stops the update process. I have a lot more space available though when I look at my volumes. (Many TB available. Thank you for your assistance
desallesp wrote: ↑04 Dec 2023, 20:56 Morning, I'm trying to update but it says my system partition is less than 8 gb and it stops the update process. I have a lot more space available though when I look at my volumes. (Many TB available. Thank you for your assistance
This has nothing to do with the available space on Volumes. It is the SYSTEM space.
There are MANY threads here discussing the details:
This is one: viewtopic.php?f=76&t=4655
Another: viewtopic.php?f=28&t=4912
What version are you updating from?
Not: Glad to see @TMsupport has, at last, restricted the update :lol: :lol:
IrisLi
Post by IrisLi »
Go to "TOS>Control Panel>System Information>Overview" and view the available space of the system partition from the "/" option.
If the system partition is less than 8GB, you can refer to this link to solve the problem.
sae24
Post by sae24 »
F4-422
5.1.95 - > 5.1.103
No essue
All fine
zedmel
Post by zedmel »
Something strange with this update.
I've try to update.
launch update, % increasing, then decreasing and increase again, decrease, several time, and at the end, update failure.
Wired.....
fer_j_lop
Post by fer_j_lop »
Good morning.
Update from 5.1.95 to 5.1.103 failed due to "The size of your system partition is less than 8GB...".
cfdisk shows 7.6G for UTOSCORE and 1.9G for UTOSSWAP coming from a fresh installation of a previous 5.1 version:
Disk: /dev/sda
Size: 7.3 TiB, 8001563222016 bytes, 15628053168 sectors
Label: gpt, identifier: F3CF1D70-9317-47D9-B75E-83F6467977F5
Device Start End Sectors Size Type
/dev/sda1 2048 585727 583680 285M Linux filesystem
>> /dev/sda2 585728 16586751 16001024 7.6G Linux filesystem
/dev/sda3 16586752 20586495 3999744 1.9G Linux filesystem
/dev/sda4 20586496 15628051079 15607464584 7.3T Linux filesystem
Free space 15628052480 15628053134 655 327.5K
lqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x Partition name: primary x
x Partition UUID: DBDE1B3B-ACAB-4CC7-8CB8-AB40C90066C2 x
x Partition type: Linux filesystem (0FC63DAF-8483-4772-8E79-3D69D8477DE4) x
x Filesystem UUID: 14951986-4f4d-9606-0313-45d5008f87d7 x
xFilesystem LABEL: TNAS:UTOSCORE-X86-S64 x
x Filesystem: linux_raid_member x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
Regards.
{L_BUTTON_AT}fer_j_lop
Is this disk all the disks in your TNAS? Do you have any other disks? What is their partition situation?
fer_j_lop
Post by fer_j_lop »
Hello.
I have 5 x 8TB disks in TRAID-5 mode wiht the partitions shown in my previous post:
Ragards.
TMlinda
Post by TMlinda »
Please contact the technical support email or customer service window on the right side of the official website homepage, and we can arrange an engineer to assist you in remote troubleshooting.
