New F2-212 Set Up - Slow Right Speeds
JohnS
Post by JohnS »
I've seen many posts about transfer speeds but nothing that really helps me. I have a new set up as follows:
F2-212
TOS 5.1.67
File service SMB
2x 3TB Western Digital RED WD30EFRX (5400rpm) RAID 1 config BTRFS
The issue is slow write speeds ~12MB/s (read speed is ~ 24MB/s
I'm new to this so apologies if you need more information. any help would be appreciated.
Re: New F2-212 Set Up - Slow Right Speeds
May I ask if RAID1 is synchronizing?
The RAID being synchronized will take up a lot of read and write performance. You can wait for the synchronization to complete before attempting again
JohnS
Post by JohnS »
Hi, no it is not synchronising. Even if it is left overnight the transfer rate is still the same the following day.
May I know how long has your RAID 1 from been setup? How do you your RAID 1 is not syncing?
JohnS
Post by JohnS »
I recall seeing a message saying 'synchronising' that isn't there any more.
I have reinstalled the TOS system today this has doubled the speed, but I still think it should be quicker. Is there a way of reformatting the drives in situ and starting again?
First of all, it doesn't seem to be a software issue, because we have exact model and software in our lab, the speed issue does not present. It is more like a networking or hardware issue, hardware defect, network issue or hard drive low respond. Please check your network connection or change a hard drive and try again.
JohnS
Post by JohnS »
Thanks for the advice.
So today I connected the TNAS directly to a PC. Transfer speed now >100MB/s, I assume that rules out any of the hardware. So it looks like a network issue which I will investigate this weekend. I'm glad it's nothing to do with the NAS / Disks.
Return to “File Services”
