Loading never ending .... F2-422
xbaeza
Post by xbaeza »
after a NAS restart i'm unable to access it anymore.
Like a read in other posts, i restarted the NAS with no HDDS so a new screen appear asking for drives. Then I've inserted the drives again, and a new screen appeared. I pressed "Initialize" and choose "Automatic". Then a HDD checking process finished with success:
HDD1 ST8000VN004-2M21 8.00 TB Good
HDD2 ST8000VN004-2M21 8.00 TB Good
After that a "Intalling TOS..." screen appear, then, NAS automatic restart.
But after that a "Loading" screen appear and after one hour of HDD working noise, it stopped and web interface is not accessible whith a connection timeout error.
Printed in the footer is this number: J3455_MAPL0303V17_V4.9.19
¿what can I do?
TMnight
Re: Loading never ending .... F2-422
Post by TMnight »
Have you tried searching for the IP address of the NAS using the TNAS PC? Can you search for it normally?
xbaeza
Post by xbaeza »
Hi!
No I don't, I will try it.
Thanks!
xbaeza
Post by xbaeza »
Hi again!
i've tried but "No TNAS device was found" message appeared.
¿Any other ideas?
Thanks!
TMlinda
Post by TMlinda »
{L_BUTTON_AT}xbaeza
You can refer to this link for troubleshooting. viewtopic.php?f=83&t=2250
{L_BUTTON_AT}xbaeza
Can you see a list of devices (aka clients) on your dhcp server (usually router)?
F5-221 TOS7.0.1105 - 4x4TB (Ironwolf) Traid
F2-424 TOS7.0.1105 - 2x500GB nvme (P3) Traid, 2x6TB HDD (HGST) Traid
F2-221 TOS7.0.1105 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1105 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
What is the TOS version you installed for F2-422?
Return to “Initialization”
