Attention: TOS 5.1 System Update
If your initial system was TOS 4.x and your system partition is 2GB, please refrain from updating to the new TOS 5.1 version. The updated version demands more storage space, and this requirement may not be met by your current system.
How to Check Your System Partition Size:
Navigate to "TOS > Control panel > System Info > Overview" and inspect the available space under the "/" section.
In the event that your TNAS does not meet the storage conditions but you wish to proceed with TOS 5.1.95, please follow the guidelines provided here: viewtopic.php?f=28&t=4912
Release Notes
Applicable Models: F2-220, F2-420, F4-220, F4-420, F5-420, F2-221, F2-421, F2-422, F4-221, F4-421, F4-422, F4-223, F5-221, F5-225, F5-421, F5-422, F8-421, F8-422, F2-223, F4-223, F2-423, F4-423, T6-423, T9-423, T12-423, T9-450
What's New:
- Compatibility update for Terra Photos version 1.2.90.
- Compatibility update for TNAS Mobile version 3.2.31.
- Added detection items for TOS updates.
- Fixed some issues in Network Services;
- Fixed some issues in App Center;
- Fixed some issues in External Storage;
- Fixed some issues in Time settings;
- Fixed some issues in File Manager;
- Fixed some issues in Certificates;
- Fixed some issues in Message Center;
- Fixed some issues in Volume;
- Fixed some issues in Shared Solder;
- Fixed some issues in Storage Pool.
- This update is exclusively intended for TOS 5.1.24 or later versions. If your current TOS version does not meet these requirements, consider updating to TOS 5 by reinstalling TOS.
- Users of TOS 5.1.37 should be aware that encrypted folders created in this version may face decryption issues in subsequent updates. It is recommended to back up data in the encrypted shared folder and delete it before proceeding with the update. This applies only to encrypted shared folders created in TOS 5.1.37.
- The kernel of TOS 5.1 has been updated to 5.15. As a result, Intel Celeron J1800/J1900 GPU drivers are no longer supported in these models. If you rely on GPU hardware video acceleration and own any of the affected models, avoid updating to TOS 5.1. These models include F2-220, F2-420, F4-220, F4-420, and F5-420.
- While the system update typically doesn't affect your hard drive data, it is strongly recommended to back up your data to ensure its safety before proceeding with the update.
Manual Update:
- Download the update package here (md5: dd0a414fc8dbe0316fa23a0ff1f98148).
- Go to TOS > Control Panel > General Settings > System.
- In the "Manual Update" section, upload the update package.
- Click "Apply."
- After the system update is complete, refresh your web browser.
- Note that your TNAS's IP address may change after the update; if you can't connect with the previous IP, search for the new IP using the TNAC PC client.
TNAS PC:
After updating to TOS 5.1, ensure that your current TNAS PC is updated to version 5.0.33 or a later version. This step is essential for searching your TNAS device.
Download TNAS PC 5.0.35 for Windows OS
Download TNAS PC 5.0.41 for macOS
It is recommended to uninstall the previous version before installing this version of TNAS PC.
Issue Report:
If you encounter any issues during use, please report them on the TerraMaster official forum, or email your issue description and screenshots to pm(at)terra-master.com.
