How to create bond (static aggregation) with vlans?
BorizzK
Post by BorizzK »
How to create bond (static aggregation ports) with 2 vlans (vlan interfaces)?
Need for connect TNAS to L3 swithch trough 2 static aggregation ports (trunk ) with 2 vlans
Re: How to create bond (static aggregation) with vlans?
You can go to the interface in the TOS control panel network service and select two network interfaces to create a BOND.
BorizzK
Post by BorizzK »
I know about bond.
My question about create trunk with vlans on bond
In general, when using static aggregation binding, it should be limited to the same VLAN.
Why don't you use dynamic aggregation implementation? Is there any special purpose?
Of course, this all requires the support and correct settings of your switch.
BorizzK
Post by BorizzK »
I have no problems setting up the switch
I configured a lot of L3 Cisco, AlliedTelesis and Ruijie switches with port aggregation for connect to vsphere hosts (esxi not support lacp, only static mode), other switches and nas Lenovo EMC2 and nas/san Infortrend EonStor
In all scenarios I needed trunks between the switch and the device to separate traffic from different vlans
What am I doing now
1. Create bond 802.3ad (lan1 and 2 configured with dhcp)
2. Configure port aggregation group (gi0/23 and gi0/24) with lacp on my Ruijie 5310-E L3 switch
3. Configure ag1 as access port with vlan
and...
no any packets from TNAS
no any mac addresses from TNAS on switch
i change aggregation mode for ag1 to static
shutdown gi0/24
traffic returns and i have access to TNAS
i connect to TNAS web-interface
but no any bonds in network configuraton page in TOS
I repeat all steps with old nas Lenovo PX6-300D - everything worked fine immideatly
I don't understand where the problem is (((
BorizzK
Post by BorizzK »
I repeated all steps on TNAS and everything is ok
For some reason, bond was not created in TNAS at first and second attempts
May be error in the web interface or tnas scripts?
TMLyy
Post by TMLyy »
The switch setup method of each brand is different. You need to confirm with the brand of the switch how to set it up.
BorizzK
Post by BorizzK »
I know, but in Cisco, Allied Telesis and Ruijie L3 switches - dynamic aggregation (w LACP) is the same
Everything works now
But
I still don’t understand how to create trunk and vlan-interfaces on bond for vlans on tnas
If you need to bond multiple VLANs (from multiple switches), these switches must be stacked and correctly configured.
BorizzK
Post by BorizzK »
I need
one switch
trunk to tnas
vlan for management (access to ssh and web-face)
vlan for nfs service
vlan for smb service
Return to “Network”
