Is the D5-300 compatible with mac os 14 ?
- [email protected]
Hi, before updating to Mac OS 14.1 I'd like to know if the D5-300 Thunderbolt is compatible with the new Mac OS Sonoma?
Re: Is the D5-300 compatible with mac os 14 ?
We need to add to you that although D5-300 can work properly under macOS14.0, the current version of TerraMaster RAID Manager cannot be used properly on macOS14.0.
If you need to create or edit RAID using RAID Manager, please operate on Windows or an older version of macOS.
- MadManSoft
Any ETA on when a compatible version will be available? This is a pretty big deal for users wanting to upgrade to MacOS 14 (Sonoma).
{L_BUTTON_AT}MadManSoft
- MadManSoft
Thanks so much, please keep us updated!
Yes, any update is more then welcome
I was not using my Terra Master for over two yers. And just had to learn that on both laptops it is a just looking brick.
So happy to see that you're working on a solution!
Same problem here. Mine was working fine on Sonoma 14.1 until I installed the recent update to Sonoma 14.1.1
To be clear, mine (on a M1 Mac mini) was working fine on 14.1 It's the latest minor update that killed it.
same here, mac mini M2 not working on 14.1.2. Raid manger can not find drives
- crisisacting
- Silver Member
At the moment, it seems that Highpoint (the OEM of the RAID controller in the D5 ThunderBolt enclosures) hasn't released an updated driver or utility for MacOS 14.× yet @ https://www.highpoint-tech.com/rr272x-overview
