Virtualbox audio problem
Vaulenst
Italy
Post by Vaulenst »
I installed Virtual Box 6.1.46 (158378) on TOS 5.1.67-00214.
I set-up a linux VM (Manjaro XFCE).
I start it from the web-interface and connect to it from Windows 11 using Remote Desktop.
I can't hear any sound.
In the linux guest I can see the volume bars moving as I play something.
I tried to change the audio controller in VB audio settings, the audio periferic in linux and the audio settings in RD but with no success.
Any suggestions?
TY
TNAS F4-423
RAM 20GB (4GB TM + 16GB Crucial CT16G4SFRA32A)
Proxmox 8.3 - OMV 7.7.3 - Dockers
SSD 1TB Lexar NM610PRO NVMe
HDD 20TB Toshiba MG10ACA20TE
HDD 18TB Toshiba MG09ACA18TE
HDD 8TB Seagate ST8000VN004-2M2101
HDD 3TB Western Digital WD30EXRX-00MMMB0
Re: Virtualbox audio problem
Hello, we are currently unable to achieve this from hardware or software. We will submit this requirement and discuss it.
Vaulenst
Italy
Post by Vaulenst »
Ok,
ty for the answer.
TNAS F4-423
Return to “Virtual Machines”
