Unable to create Duple backup task
Duple Backup has powerful backup and restore functions, and is a disaster recovery tool designed to strengthen the data security of TNAS devices.
sim667
Post by sim667 »
I'm trying to create a duple backup task to webdav remote server, and I can add the server and locations fine, I set the schedule for the backup and click complete, but at this point the last creation fails. Has anyone else had a similar problem to this?
TMtina
Re: Unable to create Duple backup task
Post by TMtina »
Hello, your backup destination space may not be enough. The specific reason must be sent a log to be clear. Please send us a log to check.
sim667
Post by sim667 »
My destination space is much larger
Ill have a dig through the logs
sim667
Post by sim667 »
Can you tell me where I’d find the logs for duple please?
sim667
Post by sim667 »
I’m being silly. I found the log it’s in duple itself.
The log entry just says “Failed to add backup task. (task_1)”
During the attempt to create the task I can see the contents of my webdav when I select the destination for the save. So this seems to be an issue with actually creating the task on duple rather than anything to do with the setup of the remote server.
Yes, please provide the log information.
sim667
Post by sim667 »
Im unable to attach the log export to the forum as it doesn't recognise csv or txt files. I've attached it as a jpg, but you'll have to download and change the file extension i think....
I have noted that duple is creating the subfolder on the webdav server, its mainly a problem with saving the task.
sim667
Post by sim667 »
Scrap that, the attachment didn't work, how can I send the log to you?
You can upload to the cloud drive and generate a sharing link. For privacy reasons, you can send a private chat, or send it to the customer service window on the official website homepage, or send it to the technical support email.
sim667
Post by sim667 »
I've sent it to you directly.
I also signed up for mega as that is a cloud drive that's available to set up directly in duple, but that doesn't work either..... So now I'm really not very happy at all.
Return to “Duple Backup”
