Hardware Sensors not working
ElPabloMaximo
Post by ElPabloMaximo »
Has anyone else noticed hardware sensors not working? It's a brand new machine so maybe a bug? No device temp, no CPU temp, no fan speed.
T12-450
TRAID Pool 1 - 2x2TB NVME
TRAID Pool 2 - 4x4TB HDD
TRAID Pool 3 - 4x6TB HDD
https://www.linkedin.com/in/paul-tippit-56496b17/
Re: Hardware Sensors not working
We have noticed similar issues and are currently investigating and repairing them.
What version of TOS are you using? Is your TNAS running some programs at full capacity?
You can try logging in to SSH and entering the following command to check the temperature of the fan, device, and CPU to see if it can be detected?
ec_stat rss
ec_stat rst
ec_stat rct
ElPabloMaximo
User and System name removed.
It appears to be more than a visual defect in the GUI
[TNAS01 ~]# ec_stat -rss
system_fanspeed = -19640
[TNAS01 ~]# ec_stat -rct
cpu_temputre = 0
[TNAS01 ~]# ec_stat -rst
system_temputre = 0
At the time this was take, CPU is @ 10% and memory is at 8% utilization.
T12-450
This may be due to a problem with the program or the wrong adaptation program being started. You can try restarting TNAS.
ElPabloMaximo
restart did not resolve this problem
T12-450
Please pay attention to the replies in your newly posted topic post.
viewtopic.php?f=25&t=5324&p=30774#p30774
