OpenVPN without ID/PSW
Brutaldeath
France
Post by Brutaldeath »
I tried to connect one OpenVPN connection with AirVPN.
After discuss with the AirVPN support team, I send this message for kwon why it's impossible to init a connection in mode "OpenVPN with import file" and stay the case "ID" and "Password" empty ? (it's impossible to clic on "apply")
Answers of AirVPN:
In this case the NAS is not OpenVPN compatible and will not connect to the services which require exclusive certificate and key authentication in TLS mode, unfortunately. It is anyway very strange because it is trivial to overcome this limitation: it's sufficient to omit the auth-user-pass directive, end of the story. It sounds weird that the user interface designers did not consider this obvious and widespread configuration and caused this critical bug. Please contact the customer service, they might offer a solution.
Image Image
F4-423
TOS 5.1.67-00214
Re: OpenVPN without ID/PSW
We have received your feedback. We will confirm and study compatibility issues with this VPN service.
Return to “Network”
