I can't see update & recovery menu
DiavoloRosso
Post by DiavoloRosso »
Hi all
In my TOS 4.2.09 i can't see update & recovery menu in control panel.
If i search the menu i can see an error "An error occurred in the application. Please uninstall it and install it again!"
Anyone know how can I update TOS without this menu or how can I restore the menu?
Re: I can't see update & recovery menu
Hi, the server for app download is now changed, and is no longer available for low version of TOS4.
Please update your TOS 4 to the latest TOS 4 version in which you can access the app server to download the apps again. (To update TOS, please go to Control Panel - Update & Recovery - Software Update)
If you have trouble updating TOS, you can consider reinstalling the latest TOS:viewtopic.php?f=76&t=423
DiavoloRosso
[RESOLVED] Re: I can't see update & recovery menu
Hi Zethar
After reinitialization I can see the menu and manage upgrade directly in TOS.
Thank you for the support
Return to “System Update”
