I have found that since 'upgrading' to TOS5 (yes I partitioned it properly), I am having all kinds of problems; The system seems sluggish, to update to the latest beta of Emby takes 30 minutes to install instead of 30 seconds like it did on TOS4.
I am using EXT4 on my F5-221 and use it only to watch things on Emby, although I have tried Nextcloud via Docker.
Should I go back to TOS4 as 5 really doesn't seem 'ready' despite TOS6 apparently being on the way, which really makes me think that won't be ready either.
Opinions please
Should I go back to TOS4?
Re: Should I go back to TOS4?
Is it just Emby updating slowly? Have you tried installing or updating other applications?
It is recommended not to downgrade to TOS4, as this may affect data.
it has been every version of Emby and my disks are spinning more often. I went back to TOS4 and all the problems went away. Staying where I am
