LAN 1 Disconected!
Tricky
LAN 1 Disconected!
Post by Tricky »
Since the 67 update I keep finding that when I go to the media server it reports it's connected to LAN2 which is not used, this happens on both F5-221 machines?
TMzzl
Re: LAN 1 Disconected!
Post by TMzzl »
{L_BUTTON_AT}Tricky
You can try to restart the system to see if this phenomenon persists
Tricky
Post by Tricky »
Sorry! Already done but problem still persists, not quite sure how long it takes to manifest as I don't check that often but will monitor and report back.
Return to “System Update”
