Rsync from F2-220 to Synology failing (code 5)
nastekindustries
Post by nastekindustries »
I've been trying to back up my F2-220 to a Synology, however the status will either be stuck on "Preparing" or I will get the error (attached).
I follows the instructions in the following link ( viewtopic.php?f=9&t=2470&p=13323 ) however I'm still getting the same issue.
Re: Rsync from F2-220 to Synology failing (code 5)
The latest version of TOS5 already supports related functions. However, if you need to use TOS5, please:
1. Backup data.
2. Connect the disks to PC, clear the hard disk partitions with disk tool.
3. Install TOS 5.0.176:
https://download2.terra-master.com/TOS_ ... 111430.ins
4. Go to Control Panel - -System - Update, update to TOS 5.1.24:
https://download2.terra-master.com/TOS_ ... 270938.bz2
5. Go to Control Panel - -System - Update, update to latest TOS version automatically.
Return to “File Services”
