After adding a custom self-signed SSL certificate, from Control Panel > Security > Certificate page, all existing certificates are disappeared from the page. This is the first time that I use this TOS feature. I can confirm that nginx and other services are working fine, because the certificate files are existing into system.
I checked this from SSH, path "/etc/nginx" and "/etc/nginx/ssl": If I try to add other certificates from Control Panel, the system tells me that already exist, but it's not true.
And if I click Confirm, I cannot see the certificate. I tried to reboot the TNAS but the problem still happen.
Could you kindly check what's wrong in Certificate page?
Below, my system specs:
- TNAS F4-423
- TOS 5.1.67 (x86-64) > fresh installed some weeks ago
