Motion detection fails
A CCTV monitoring and recording application
gosavip
Post by gosavip »
I recently purchased an F2-223 with TOS 5.1.67-00214. I am running Surveillance Manager 0.1.34.
I have setup an Amcrest camera (IP2M-B41B) with Surveillance Manager and would like to record video only when motion is detected. When I set the schedule to Motion Detection (all green) and set Event Detection source to Camera, i get continuous recording even though there is no motion. When I clear the schedule (all white) and set Event Detection source to Camera, I get no recording even if there is motion.
I know this is not a camera issue because when I go back to the original Amcrest systemmotion detection works. How can I get recording with motion detection using Serveillance Manager?
Thank you
Re: Motion detection fails
The Servillance Manager application does not have the function of only recording motion pictures
gosavip
Post by gosavip »
I dont understand. So what is the purpose of Motion Detection option or Event Detection - Camera option in Camera settings?
Sorry, currently the Servillness Manager can only set scheduled recording through scheduled tasks. Regarding the action detection recording function, it is temporarily invalid
We have a corresponding development plan and will soon release a new version of Servillness Manager, which will support motion detection. You can view the detection results in the recording and timeline functions.
gosavip
Post by gosavip »
Thank you. When will you release the new version? Do you have a date?
Preliminary estimate is 2-3 weeks, which may be advanced or delayed depending on the situation.
aschang
Post by aschang »
Hello same issue with application installée today. Even with all schedule blanked there is a continuous record.
Could you please clarify it?
TMpzhen
Post by TMpzhen »
Can you describe your problem in detail? Or send us some screenshots.
AES
Post by AES »
I was able to connect all four of my cameras, but only via RTSP, no matter how I tried to connect via ONVIF, it did not work, on Synology everything was simply added by camera model or universally. I enabled ONVIF in the camera settings, but Terramaster simply writes an error when trying to connect. With RTSP, you need to specify the correct stream, like stream101/channel=101, it is done rather complicatedly.
Hikvision DS-2CD2523G0-IWS
Hikvision DS-2CV2Q21FD-IW
Hikvision DS-2CD2443G0-IW
HiWatch DS-I202 D
I could not set up motion detection.
Either motion detection is related to ONVIF, or is performed by the camera, or I did not understand anything, or it has not been implemented.
TOS 6.0.535
Surveillance 1.0.054
TerraMaster F8, TerraMaster F2-425, Syno 218+
deltwo
Post by deltwo »
I am trying to setup 2 Reolink cameras on my F4 423 I have upgraded to TOS 6 just to get the hyper cach to work. Now I find out here that Surveillance Manager app is mostly none functioning. I really wish this would be clear when one is looking at the TerraMaster info before one makes a purchase. I had both these cameras working fine on Synology. I decided I would upgrade to a 4 bay and now find out what a mistake that was as so many of the apps are none functioning if you are not a computer programer.
Return to “Surveillance Manager”
