VPN connection fails after F4-220 upgraded to TOS 4.1.24
RonnyK
Post by RonnyK »
After I have upgraded F4-220 to TOS 4.1.24, connections through VPN always fail. Everything worked well in older TOS
Re: VPN connection fails after F4-220 upgraded to TOS 4.1.24
A new version of VPN Server has been released on Saturday, please update your VPN Server to see if it's better.
RonnyK
Post by RonnyK »
The issue mentioned above is not related to VPN server, but VPN connection to 3rd party VPN service providers.
Is it ok to let our engineer have a remote session to check for you? Please send en email with detailed information to support(a)terra-master.com.
RonnyK
Post by RonnyK »
After I have installed latest TOS version 4.1.27. all issues were fixed. VPN connection issues been resolved and now you can connect your NAS to VPN service provider. What more, I have found out that Dropbox app in TOS started working too. In TOS 4.1.24. it became CPU hog and never finished initial dropbox log on. qBittorrent app started working aswell. in TOS 4.1.24 installed app was permanently switched off and I was unable to turn it on. It seems like TOS 4.1.27. is fixing loads of issues caused by TOS 4.1.24. Well done.
Thanks for the feedback and glad to know TOS4.1.27 helps you a lot.
UppedG
Post by UppedG »
I have the same issue, with PPTP, L2TP, and OpenVPN. I was hoping upgrading to 4.1.27 would fix the issue, but I still cannot connect as a client to my VPN.
UppedG » Today, 02:30
Please send an email with detailed information to support(a)terra-master.com, and we will arrange a remote session to check.
RonnyK
Post by RonnyK »
UppedG wrote: 01 Jul 2020, 02:30 I have the same issue, with PPTP, L2TP, and OpenVPN. I was hoping upgrading to 4.1.27 would fix the issue, but I still cannot connect as a client to my VPN.
Thsi topic was created for the other issue. You are having issue with VPN Server (TOS app). Issue I have stated here was related to connecting your NAS to 3rd party VPN service providers (Control Panel/Network/VPN Connection) just for Your information. All good here ;-)
Return to “Network”
