TNAS mobile 3 ver.3.2.28 is not updated
ostaporomo
Finland
Post by ostaporomo »
On the Pixel 7 mobile phone (Android 14) TNAS mobile 3 ver.3.2.25 is installed.
A few days ago a message appeared that an update to version 3.2.28 had been released.
But the application cannot update in any way. It looks like the developers broke the update mechanism in ver.3.2.25.
I have two questions:
1. Why is the application not updated through the Google Play store?
2. Where can I download version 3.2.28?
TNAS F2-223
TOS 5.1.79-00214
2x RAM Samsung 16GB DDR4 2133 MHZ
2x HDD Segate IronWolf ST4000VN008 4TB [RAID1]
DAS D4-300
2x HDD Seagate SkyHawk ST3000VX010  [RAID1]
2x HDD Toshiba DT01 DT01ACA300-3TB
Re: TNAS mobile 3 ver.3.2.28 is not updated
{L_BUTTON_AT}ostaporomo
The TNAS mobile app for Google Application Center is still under review, and you can now download and install it using the official website link. https://download2.terra-master.com/TNAS ... 3.2.28.apk
ostaporomo
Finland
{L_BUTTON_AT}TMzethar
Can I not have a direct link to the file, but give me a link to a page on which I can follow the release of new versions of TNAS mobile, so that I can follow the development of the program? I couldn't find it on my own. Thank you!
TNAS F2-223
TOS 5.1.79-00214
DAS D4-300
For versions with significant updates, we will publish notifications on the 'Update Notifice' page of the forum.
For some versions with minor changes, we will not notify you in the forum, but you can see them in the application market.
ostaporomo
Finland
The version you posted does not install on Android 14. After the “install or cancel” dialog box appears, I select install, but nothing happens. Other *.apk files are installed on the phone without problems. Permission to install from unknown sources has been granted.
TNAS F2-223
TOS 5.1.79-00214
DAS D4-300
You need to set the app settings for your phone, or please wait for the Google Store version.
ostaporomo
Finland
What else do you think needs to be configured on the phone other than allowing the installation of applications from unknown sources? What other settings are required for installation?
After all, all the other *.apk files that I downloaded not from Google Play are installed.
It would be very interesting to know for my general knowledge development how to use a mobile phone.
Thx
TNAS F2-223
TOS 5.1.79-00214
DAS D4-300
Don't live on the bleeding edge :D Android 10 loaded fine via in-phone update.
ostaporomo
Finland
[at=Gremlin post_id=30284 time=1697036846 user_id=6052][/at]
Thanks for your feedback!
Apparently, the developers made a mistake in the new version, since the previous version of the application works fine on Android 14.
TNAS F2-223
TOS 5.1.79-00214
DAS D4-300
{L_BUTTON_AT}dataonly
We have not reproduced the situation you mentioned.
You have posted a question unrelated to the topic. If you cannot find a suitable topic, please create a new one yourself
