Hi
I am using a new D4-300 purchased from Amazon. I have 3 x 8TB and 1 x 10TB drives installed. I am getting very slow transfer speeds between the drives. The max speed I see is 20MB/s. Most of time it is around 17MB/s.
I am using Windows 11 Pro on a 1.5 year old Lenovo Legion T5 with Ryzen 7 5700G and 48GB of RAM. The windows 11 pro is using the default windows drivers (see attached).
I have tried the FAQ posted here viewtopic.php?f=86&t=448 with no success.
The FAQ says:
1. small files can be slow: all of my files are bigger than 1GB with the biggest being around 6GB
2. failure of hard disk: As per CrytalDiskInfo all of my drives are in Good health (see attached)
3. I am using the original USB cable. I have even tried a 100Gbps USB type C to type C cable but it make no difference
4. The USB on my computer is NOT faulty. It works without any issues with everything. I even tested all my ports with a Mediasonic 4 drive bay and all drives there get very good transfer rates
5. I do NOT have a USB hub
I am all out of ideas. Would appreciate some help please.
D4-300 very slow transfer speeds
Re: D4-300 very slow transfer speeds
Please update the USB driver of your computer, and try again.
- Mediasonic
TMLyy
You need to verify it with other devices, which can be used under the same conditions on the D4-300 device.
Because the speed is only 20MB/s, USB 2.0 speed is not reached.
- Mediasonic
I have tried my Samsung T7 flash drive on the USB port and it has excellent transfer speeds. I have tried an external seagate and I am getting 70+ MB/s on the same size file (3GB file) on all of my USB ports.
I tried the D4-300 with my Dell XPS laptop and I am getting the same speeds (17-20MB/s). Dell XPS only has 2 USB 3.1.
What else can I do?
- Mediasonic
Update:
Unplugged everything from the machine, restarted and then replugged everything. Not sure what has happened but the transfer speeds are great now. I am getting 100+ on all drives.
Thanks for your help.
Hello i have the D4-300 USB 3.1 what do you use if i wanted a couple of drives to be put into Raid 0?
What software is used?
- crisisacting
- Silver Member
