SSL problem
avitabileproduction
SSL problem
Post by avitabileproduction »
Hello, i need help to better understand few things
I set up remote access via DNS and NO IP, to test and understand how it work
I then enabled https and opened the ports on the router
but when I try to connect remotely via https, I read a warning "site not secure, ssl not recognized"
the connection occurs correctly in https, so I was able to open the port correctly, the only problem remaining is the unrecognized SSL and the dangerous site warning
can you help me?
TMeric
Re: SSL problem
Post by TMeric »
The current version does not support custom https SSL certificates, this feature is under development.
Return to “Network”
